Summary:
On March 16th, 2022 ISC announced a new security issue encountered in BIND 9.18.0 as CVE-2022-0667.
Overview:
We refactored the RFC 8198 Aggressive Use of DNSSEC-Validated Cache feature (synth-from-dnssec) for the new BIND 9.18.0 stable release, and changed the default so that is now automatically enabled for dnssec-validating resolvers. Subsequently it was found that repeated patterns of specific queries to servers with this feature enabled could cause an INSIST failure in query.c:query_dname which causes named to terminate unexpectedly.
The vulnerability affects BIND resolvers running 9.18.0 that have both `dnssec-validation` and `synth-from-dnssec` enabled. (Note that `dnssec-validation auto;` is the default setting unless configured otherwise in `named.conf` and that enabling `dnssec-validation` automatically enables `synth-from-dnssec` unless explicitly disabled).
Impact:
When a vulnerable version of named receives a series of specific queries, the named process will eventually terminate due to a failed assertion check.
CVSS Score: 7.0
CVSS Vector: CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H/E:F/RL
/RC:C
For more information on the Common Vulnerability Scoring System and to obtain your specific environmental score please visit: https://nvd.nist.gov/vuln-metrics/cvss/v3-calculator?vector=AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H/E:F/RL
/RC:C&version=3.1.
