NETMRI does not detect all routing table entries
3653     0
Hello everyone.I want to detect all the routes for a specific device and use that array in my python scripts. I used this API request:
http://NETMRI_server/api/2.10/device_routes/find?op_DeviceID==&val_c_DeviceID=45
and i have the following  result:
<response>
<total type="int">773</total>
<start type="int">0</start>
<limit type="int">1000</limit>
<current type="int">773</current>
<device_routes type="array">
That means what NETMRI is detecting only 773 routes, but when in fact when i print Check the routing Table using cisco CLI i have more than 15000 (show ip route vrf *)
Should I use a different query for my need?
Re: NETMRI does not detect all routing table entries
3654     0
Try using the VRF View name as well
https://sifbaksh.com
