DNS DHCP IPAM
Accepted Solution
Configuration LAN2 as OSPF Interface
1928     0
Hi all,
Good day to you guys.
I would like to ask you about configuration LAN2 interface as OSPF advertisement interface for ANYCAST.
When I check the config for Anycast using OSPF, there is no selectable button for LAN2. Only found for LAN1. So, I thought that may b I didn't set DNS interface for LAN2. Then I did and check again OSPF Anycast config. Still no config for LAN2. I want to know that LAN2 interface is not available for OSPF advertisement or what?
Thanks!
MM
Re: Configuration LAN2 as OSPF Interface
1929     0
Hello MM,
Unfortunately at present we do not have the option to support OSPF in LAN2.  We do have a feature request for the same which has been internally identified as RFE-2798.
Hope this helps.
Manu M
1929     0
Hi Manu M,
Can u please inform if we already have this option? In order to enable OSPF in LAN2.
BR,
Paulo Fragoso
1929     0
It's unfortunately still not possible to run OSPF on LAN2. I would recommend you get in touch with your account team in order to receive updates on the above mentioned feature request RFE-2798.
It is possible to run anycast using BGP on both LAN1 and LAN2. Thank you.
Jelle
Escalations Engineer EMEA
1929     0
Hi Jelle,
Thanks for your feedback.
Can we have, Anycast working with OSPF in LAN 1 and Anycast working with BGP in LAN 2?
BR,
Eng. Paulo Fragoso
1929     0
Yes, that should be possible. However, I stronly advise you to test that scenario and also discuss it with your Infoblox account team. Thank you.
Jelle
1929     0
Ok Thanks.
I will test it.
BR,
1929     0
Unfortunately at present we do not have the option to support OSPF in LAN2. We do have a feature request for the same which has been internally identified as RFE-2798. https://audacity.onl/
https://mails.tips/temp-mail/
https://origin.onl/
