DNS DHCP IPAM
how to get next available network from a ipv6 container using _function=next_available_network
Not applicable
1652     0
Hi, There:
When I tried to use _function=next_available_network to get next available network from a ipv6 container, it will complain bad request, but if works for a ipv6 network. why is that? does it support get next available network from a container just like what it does from ipv4?
thanks.
/zhenwu
Re: how to get next available network from a ipv6 container using _function=next_available_network
1653     0
Hi ,
I ran into a similar issue testing this.
At this point, I would suggest opening a support ticket for this.
Sandeep
