API for Wireless Access points on a Wireless Controller
2399     0
As NetMRI version 7.2.1 now shows the access point table on wireless controller I'm looking for a way to raise a custom issue whenever an access point is located in the default AP group.
When looking at the access point table in the NetMRI GUI I can see the info about the AP group in the VLAN column of that table.
Is there a way to retrieve this info via an API call and thus raise a custom issue?
Re: API for Wireless Access points on a Wireless Controller
2400     0
I'll have to get an AP for our NetMRI LAB Smiley Happy
But I will also check the API docs
https://sifbaksh.com
