Accepted Solution
Is it possible to call a CCS script from a Perl script?
2737     0
I would like to do some checks, etc. in a Perl script and then if conditions are met, kick off the example Cisco IOS firmware upgrade CCS script. Is that doable (and if so, without tons of frustration)?
Re: Is it possible to call a CCS script from a Perl script?
2738     0
Yes, there is an example in the Perl Tutorial that launches a script from an another script. Take a look there.
