Is there a guide for using RegEx config searches?
2390     0
Is there a better guide for how to use search with Config Text RegEx.
For example if I am searching the configurations for
192.168.130.0/23
I have to type this
^/192.168.130.|192.168.131./
This does get the job done, and retuns all the devices that matches, but it gets convoluted when you are searching against 10+  segments that are non-contiguous
I tried using this as a search, but no luck
^/192.168.13[0-1]./
Any help around searching IPs within teh configuration file would be very much appreciated
Re: Is there a guide for using RegEx config searches?
2391     0
Can you post a few strings of where the IP address might be shown?
Trying to understand how the REGEX should be build
THanks
https://sifbaksh.com
2391     0
Let me know if solve your problem
