Learn How We Can Help You Keep Teleworkers Safe During the COVID-19 Crisis
Issue View Limitation?
1154     0
My recent script generated over 6000 interface issues. I have noticed that the Issue Viewer only displays 2000. Is this a bug or some sort of settable limit? I have tried the export, thinking that would include all, but it does not. I also tried filtering and that doesn't get to all of them either.Thanks - Lon.
