Application Uptime Dashboard
5324     1
The Application Uptime Dashboard provides a view of the core network services require to support network based applications. If your applications are slow or not responding, this dashboard will rule out DNS as the reason.
One of the interesting features is the top two boxes which do anomoly detection of DNS and DHCP usage patterns. This can detect a large number of potential scernarios which could impact DNS/DHCP/Application performance.
screencapture-demogm1-infoblox-com-ui-T3dVLco5y5awaLZejjiIEQ-T3dc4-VLc9c-1470780986274.png
<dashboard>
<label>Application Uptime </label>
<description>Application Uptime Dashboard</description>
<row>
<panel>
<single>
<search>
<query>index=ib_dns_summary report=si_dns_qps_trend |stats sum(COUNT) as COUNT by _time TYPE | timechart limit=18 bins=1000 eval(avg(COUNT)/600) by TYPE useother=f | interpolate 1200 |head 1 | eval health = if(A&gt;1, "Normal", "Abnormal")| eval ok_level=if(A&gt;1,"low",null()) | eval sev_level=if(A&lt;0,"severe",null()) | eval level=coalesce(ok_level,sev_level) |table health level</query>
<earliest>0</earliest>
<latest></latest>
</search>
<option name="colorBy">value</option>
<option name="colorMode">none</option>
<option name="numberPrecision">0</option>
<option name="rangeColors">["0xd93f3c","0x65a637"]</option>
<option name="rangeValues">[0]</option>
<option name="showSparkline">1</option>
<option name="showTrendIndicator">1</option>
<option name="trendColorInterpretation">standard</option>
<option name="trendDisplayMode">absolute</option>
<option name="trendInterval">auto</option>
<option name="useColors">1</option>
<option name="useThousandSeparators">1</option>
<option name="classField">level</option>
<option name="linkView">search</option>
<option name="field">health</option>
<option name="underLabel">DNS Activity</option>
</single>
</panel>
<panel>
<single>
<search>
<query>index=ib_dns_summary report=si_dns_qps_trend | stats sum(COUNT) as COUNT by _time TYPE | timechart limit=18 bins=1000 eval(avg(COUNT)/600) by TYPE useother=f | interpolate 1200 |head 1 | eval health = if(A&gt;1, "Normal", "Abnormal")| eval ok_level=if(A&gt;1,"low",null()) | eval sev_level=if(A&lt;0,"severe",null()) | eval level=coalesce(ok_level,sev_level) |table health level</query>
<latest></latest>
</search>
<option name="rangeColors">["0x65a637","0x6db7c6","0xf7bc38","0xf58f39","0xd93f3c"]</option>
<option name="rangeValues">[0,30,70,100]</option>
<option name="useColors">0</option>
<option name="underLabel">DHCP Activity</option>
</single>
</panel>
</row>
<row>
<panel>
<title>CPU Utilization</title>
<chart>
<search>
<query>index=ib_system_summary report=si_cpu_usage earliest=-1d | timechart bins=1000 avg(CPU_PERCENT) by orig_host where max in top5 useother=f | interpolate 1200</query>
<earliest></earliest>
<latest></latest>
</search>
<option name="charting.drilldown">all</option>
</chart>
</panel>
</row>
<row>
<panel>
<chart>
<title>Traffic Rates</title>
<search>
<query>index=ib_system_summary report=si_traffic_rate | rename orig_host as host | timechart bins=1000 avg(TRAF_VALUE) by MEMBER where max in top5 useother=f | interpolate 1200</query>
<earliest>@d</earliest>
<latest>now</latest>
</search>
<option name="charting.chart">area</option>
<option name="charting.chart.stackMode">stacked</option>
</chart>
</panel>
</row>
<row>
<panel>
<chart>
<title>DNS Response Latency Trend</title>
<search>
<query>index=ib_dns_summary report=si_dns_response_latency_trend| rename orig_host as host | timechart bins=1000 avg(LATENCY) by host where max in top5 useother=f | interpolate 1200</query>
<latest></latest>
</search>
</chart>
</panel>
</row>
<row>
<panel>
<chart>
<title>DNS Query Trend</title>
<search>
<query>index=ib_dns_summary report!=si_dns_member_qps_trend_per*| timechart span=1h count by report limit=6</query>
<earliest>-30d@d</earliest>
</search>
</chart>
</panel>
</row>
  <row>
    <panel>
      <html>
        <div style="text-align: right;margin-top:0;;margin-bottom:0">
        <h1>Developed by <a href="http://www.maxonic.com" target="_blank"><img src="http://maxonic.com/wp-content/uploads/maxonic_logo_small.png"/></a>
        </h1>
        </div>
      </html>
    </panel>
  </row>
</dashboard>
Re: Application Uptime Dashboard
5325     1
Thanks a lot, It is aldready a classic. Do you plan a updated version that allow to filter on members to deal with grid with more than 5 members?
5325     1
cool, any update for more that 5 infoblox server  let say 30
Chris
