DNS Success Rate per Domain
3186     0
Hi Guys,
is there anyway to modified Reporting to collect Success Rate for specific domain (not per member)? Let's say i want to know about the count of successful query for "youtube.com", also the failure one. Looking forward for your any suggestion guys.
Ramadian
Re: DNS Success Rate per Domain
3187     0
Hi Ramadian,
Unfortunately it is not possible with the standard data. This is because Infoblox summarizes data on the grid member before sending it to the reporter. The particluar combination of data you are looking for is not summaried.
It is possible to do if you were to add the Data Connector to capture query logs though. It would just be a matter of building the appropriate search from that data set. If you go that route let us know and we can help you build the search.
-Roger
3187     0
Hi Roger,
Thanks for your advise, i'm trying to find out how to use Data Connector as well. I have an example that might deliver to you of what im trying to looking  atimage.png
Ramadian
3187     0
It should be possible to build an almost identical report using the data from the Data Connector.
