System Reporting Capacity Dashboard
4727     2
This dashboard helps administrators get better visibility into the index utilization and overall capacity of the reporting server.
Screenshot 1
Screenshot 2
<dashboard>
<label>System Reporting Capacity Dashboard</label>
<row>
<panel>
<table>
<title>Disk Usage by Index</title>
<search>
<query>|rest /services/data/indexes |eval space=round((maxTotalDataSizeMB-currentDBSizeMB)/1024 ,2)|table title minTime currentDBSizeMB space | where minTime!=""| rename currentDBSizeMB to "Current Size in MB" , minTime to "Oldest Event" , title to "Index" ,space to "Space Left in GB"</query>
<earliest>1455691606.000</earliest>
<latest></latest>
</search>
<option name="count">20</option>
</table>
</panel>
</row>
<row>
<panel>
<single>
<title>Total Disk Usage</title>
<search>
<query>index=_internal source=*metrics.log group=per_index_thruput | eval totalMB = round(kb/1024,2) | chart sum(totalMB) as MB</query>
<latest></latest>
</search>
<option name="colorBy">value</option>
<option name="colorMode">none</option>
<option name="numberPrecision">0</option>
<option name="rangeColors">["0x65a637","0x6db7c6","0xf7bc38","0xf58f39","0xd93f3c"]</option>
<option name="rangeValues">[0,30,70,100]</option>
<option name="showSparkline">1</option>
<option name="showTrendIndicator">1</option>
<option name="trendColorInterpretation">standard</option>
<option name="trendDisplayMode">absolute</option>
<option name="trendInterval">auto</option>
<option name="underLabel">Megabytes</option>
<option name="useColors">0</option>
<option name="useThousandSeparators">1</option>
</single>
</panel>
<panel>
<chart>
<title>Index utilization comparison</title>
<search>
<query>index=_internal source=*metrics.log group=per_index_thruput | eval totalMB = round(kb/1024,2) | chart sum(totalMB) as MB by series</query>
<latest></latest>
</search>
<option name="charting.chart">pie</option>
<option name="charting.drilldown">all</option>
</chart>
</panel>
</row>
<row>
<panel>
<chart>
<title>Index Usage Trend</title>
<search>
<query>index=_internal source=*metrics.log group=per_index_thruput | eval MB=kb/1024
| timechart span=1d sum(MB) by series | fields - VALUE_*</query>
<earliest></earliest>
<latest></latest>
</search>
<option name="charting.chart">area</option>
<option name="charting.chart.stackMode">stacked</option>
</chart>
</panel>
</row>
<row>
<panel>
<html>
<div style="text-align: right;margin-top:0;;margin-bottom:0">
<h1>Developed by <a href="http://www.maxonic.com" target="_blank"><img src="http://maxonic.com/wp-content/uploads/2016/06/maxonic_logo_small.png"/></a>
</h1>
</div>
</html>
</panel>
</row>
</dashboard>
Re: System Reporting Capacity Dashboard
4728     2
Great one, works in a single step. Very interesting to see the impact of the 7.3.200/7.4 Syslog redirection to the reporting.
Note: the three last reports can take a while to be fully rendered when reporting is deployed for months
Screenshot 1
Screenshot 2
4728     2
How we can check current DDI memebr hardware configuration like
Total / Numbers CPU cores -
Total memory-
