Infoblox and Cisco Wireless APs
Not applicable
27667     0
Hi Guys,
We're trying to deploy some Cisco 2600 access points and need to issue option 43 and option 60 in DHCP so that the APs get directed to the correct wireless controller. The AP isn't registering on the controller so I'm guessing that these options are not being passed correctly and I'm doing something wrong.
Has anyone done this before or are there any guides available for infoblox and Cisco wireless APs? I've found a doc on Windows server and for DHCP on a Cisco switch but nothing for Infoblox.
Any help appreciated.
thanks,
Eric
Re: Infoblox and Cisco
27668     0
Not applicable
27668     0
Many thanks Axel, I'll give this a go.
Eric
27668     0
I tried to follow the link given, but seems the link is no longer valid.
Anyone can share the solution for this problem?
Thank you
Re: Infoblox and Cisco Wireless APs
27668     0
I ran into an incompatibility issue with Cisco AP 4800 (8.10) and Infoblox (7.3.2).The Infoblox will not provide IPs via DHCP to these APs.The same set up works fine with 3702s and 3800 series APs.
Performed the following troubleshooting test:
  1. Connected a laptop to the same switch port and received an address on the correct VLAN / subnet = Infoblox is working correct for this scope
  2. Created a DHCP scope on the same L3 switch that SVI resides for that VLAN, all APs got their IPs = the APs boot up process and DHCP request process works fine.
  3. Tried couple different IPs for DHCP relay to Infoblox, I tried couple grid members as well as the grid master.
Let me know what you think...
Indigo Card
27668     0
I would open a support ticket
https://sifbaksh.com
