Getting Started
HA pair on multipod ACI problem, multicast keepalives HA pair in different pods
1867     0
With a physical HA pair with each node in a different ACI pod (Multipod setup)
During reboot of one of the IPN nodes and the heartbeats of the HA infoblox units is going over that IPN node in the ACI fabric, the passive node will resart it's nics (HA interface and the lan interface) this will take about 3 minutes.The active node keeps functioning without any issues and the clients using DNS/DHCP didn't notice this
We noticed this during troubleshooting of an A10 AVCS, vrrp-a cluster. When also one of the IPN nodes was rebooted both A10 nodes became active and this disrupted the traffic flow.
This was solved by setting HA keepalives to unicast instead of the default multicast mode.
It looks like devices using only multicast for heartbeats can have issues if there is a disruption.
on the interpod network of an ACI multipod fabric.
Maybe encrypted VPN tunnel between HA pairs can be used for extra keepalive check ?
Re: HA pair on multipod ACI problem, multicast keepalives HA pair in different pods
1868     0
Hi, thanks for sharing this information that's good to know.
Mini Militia App Lock
