Automation Scripts
Cisco 9300 Switch automated upgrade with CCS
1600     0
Am trying to upgrade a bunch of 9300 switches.
The initial command is passed to the switch but then it needs a yes to save the config to proceed.
Part way thru the install (5-15min later) it asks to enter a yes to confirm and continue the install, then the switch will reload to finish the about 10-45min later.
How does one put this into the script?
Yes the Output Trigger does nothing but I could not decide what to look for & how to add it to the script.
Any help would be great!
Stan
Below is the CSS script I have tried:
Script-Filter:
$Vendor eq "Cisco" and $Model like /9300/
Script-Variables:
$Commands_to_be_Executed text "Enter commands here, one per line"
Action:
Copy from TFTP IOSXE to flash
Action-Description:
Executes the command to start the IOS image upgrade.
Action-Timeout:
5400
Action-Commands:
install add file flash:cat9k_iosxe.17.09.04a.SPA.bin activate commit \r\ry\ry\r
dir
Output-Triggers:
Check Download Complete
Trigger:
Trigger-Variables:
$dir_1 string
Trigger-Template:
flash://[[$dir_1]].+
Trigger-Commands: {$dir_1 like /$dir_1/}
exit \r
The session output is:
STHR1L3>enable
Password:
STHR1L3#
STHR1L3#terminal no monitor
STHR1L3#terminal no editing
STHR1L3#terminal length 0
STHR1L3#install add file flash:cat9k_iosxe.17.09.04a.SPA.bin activate commit
y
y
install_add_activate_commit: START Thu Dec 14 22:59:30 EST 2023
System configuration has been modified.
Press Yes(y) to save the configuration and proceed.
Press No(n) for proceeding without saving the configuration.
Press Quit(q) to exit, you may save configuration and re-enter the command. [y/n/q]e
[y/n/q]x
[y/n/q]i
[y/n/q]t
[y/n/q]^J
[y/n/q]
*** Job Failed [1] ***
Re: Cisco 9300 Switch automated upgrade with CCS
1601     0
I'm not directly answering your question but offer a few thoughts, having done this successfully for bundle mode.
1) As you said, each of the steps take many minutes.  The default script timeout is 5 minutes so that may be why the job errors out.
2) This script assumes that the file is already in flash.  Why not have the script download the file from your repository -- using HTTP(S)?
3) The install method is thorough in checking but can result in unexpected prompts.  And the when it succeeds, the box reboots and the script errors out.  The benefit is a slightly faster boot time -- is that worth it, compared to bundle mode?
I have a CCS script for 9200Ls (same logic) that uses the bundle (.bin) mode.  It frees space in flash by not touching the running image file (or packages/.SPA).  If the desired new file is not already present (and passes "verify"), it copies that file via HTTP from a respository.  And does "verifiy" on that.  If all is well, it modifies the "boot system" statements to boot the new file followed by the current file/method.  It then reports the actions taken in a custom issue.
We chose to only stage the upgrade and later trigger the reload during a maintenance window.
In the future, when a new baseline is declared, you change the desired image file name and do it again.
HTH
