Different actions depending on switch prompt (perl, netmri easy)
3665     0
Running these versions :
NetMRI Version : 7.4.2.97106
API Version : 3.4
NetMRI_Easy : 0.6
Script languange : Perl
Im looking for a way to check the prompt a cisco device is returning after a sent command and take appropriate actions. Prompt does change depending of outcome of command, sometimes its "]" and sometimes its "#".
If prompt = "]" then send command "yes"
If prompt = "#" then send command "copy run start"
Is this possible? If, then how?
Br
Magnus
Re: Different actions depending on switch prompt (perl, netmri easy)
3666     0
Can you past the examples of what commands you are sending and what it returns and is it all the same OS type like IOS/NX-OS or a mixed bag that you are running it on?
https://sifbaksh.com
3666     0
Also here is an example in CCS not sure about PERL or Python but let me do some research
Output-Triggers:
        router context Enterasys
Trigger: router context Enterasys
Trigger-Filter: $Vendor eq "Enterasys"
Trigger-Context: true
## Command to enter a new context - this could involve a change in the prompt structure
Trigger-Context-Enter: enable
## Regular expression that defines the prompt structure for this context
Trigger-Context-Prompt: .*#
## Command to leave the context - the regular expression prompt structure will be reverted to what it was before.
## NOTE: This is the last thing in the trigger that is processed (i.e. after all Output-Triggers have finished).
Trigger-Context-Exit: exit
## Run some commands within this context
Trigger-Commands:
        configure
        ip route $Network $SubnetMask $Router $Metric
        exit
## Process the output of the above commands
3666     0
switch#install remove inactive
If there are files eligable for deletion it will ask this question :
Do you want to remove the above files? [y/n]
Otherwise it just ends back in the regular prompt :
switch#
if prompt "]" then "y"
else do nothing.
Br
Magnus
(edited incorrect spelling)
3666     0
You can use the following
install remove inactive \ry
or is it
install remove inactive y\r
Will do it for you
