Community,
Has anyone deployed letting non-Infoblox teams use the API thru automation to access production environment to make changes? How are permissions/governance handled to limit what is changed?
Bryan
Good day Bryan
The best way to achieve this would be to create a role with specific functions. You then assign that role to an admin group (create different admin groups for different roles and permissions).
When creating the admin group, you select the type of access the user will have to the NIOS Grid (GUI, API, CLI etc). Below is an example of where in the admin group you can set the interfaces.
You then configure a specific user account for that user and assign them to the correct admin group.
Please test this out and let us know if you have any other issues.
Regards
TW
This was helpful!
