I am trying to the the options for the Required, Recommended, and Optional for the extensible attributes using the WAPI.
I am "reinventing" the wheel because we need a custom GUI for our use case with Infoblox. I've done everything that I need to do, except I can't find the said options/fields using the infoblox WAPI. I can manually set it in the custom GUI if it is required, recommended, or optional, but the problem now is that it is still possible for upper level users to use the NIOS GUI which makes having these options in the custom GUI not a possible plan.
Before anyone says anything, yes this can be solved by having a proper workflow or process, but I am just wondering if it is possible to get the extensible attributes options for required, recommended, optional fields. This way, I can have the workflow be, create extensible attributes in the NIOS GUI instead of custom GUI.
Any help would be appreciated.
