THE GAME HAS CHANGED
How to keep subzones while deleting parent zone using WAPI
1331     0
I'm using such WAPI call
DELETE /wapi/v2.12/zone_auth/xxxxxxx
to remove a certain zone, and found all subzones are also deleted
is there a parameter to keep subzones, only to delete the specified parent zone?
Re: How to keep subzones while deleting parent zone using WAPI
1332     0
Unfortunately not, this behavior is only available in the GUI.
1332     0
thanks for your answer
