Automation Scripts
Cisco WLC exit command not required.
4050     0
Im trying to save Cisco WLC configuration via CCS, NetMRi.
I have it working with the   save config\ry   logout  commands.  However, CCS submits an exit command.
it is not required.
does anyone know how to supress the exit command?
Re: Cisco WLC exit command not required.
4051     0
Can you please share the CCS script by exporting it from NetMRI (Job Mgmt > Scripts > Export)?
-Kishore
4051     0
Hey Jo,
As per design, we use 'exit' for all Cisco devices. But currently we have developed a patch file which executes "logout" to close the CLI sessions of Cisco WLAN controllers instead of "exit" command. Please open up a support case so that we can provide you the patch file and get this fixed.
-Kishore
