Automation Scripts
Need help in NETMRI Script Creation for generating CSV under triggered Jobs section
1660     0
I have a use case of writing a python script under Triggered Jobs section of Netmri for Policy rule violation trigger type
Instead of writing a Adhoc Command under violation Section, We have to write a python script with following details
Trigger Type: Policy Rule
Trigger Event: Rule Id(Eg: QOS_PL13.1)
Device Group: Selected One (Eg: QOS-WAN-ASR)
Python Script should produce the following output
A CSV file should be generated containing following columns
RULE ID(Primary Key),    DEVICEID,    DEVICE IP,    RULE STANDARD CONFIGURATION,   RUNTIME DEVICE CONFIGURATION
Imp Note:
  • RuleID  and standard configuration can be hardcoded for specific Device Group. RuleID can also be stored from Trigger Event field in CSV
  • Runtime Device Configuration, DeviceID and Device IP can be taken by logging in to the device.
  • for every Rule Id, we will create different scripts containing similar logic to create csv file. Only command to fetch Runtime device configuration will change.
  • This script will only be executed in case of any violations of policy rule
 Query:
Is there any possiblilty of creating csv/excel file from script execution with triggered job section. if yes, where the csv will be stored.
Sample Configuration which can be used:
Rule ID:
QOS_PL13.1
RULE STANDARD CONFIGURATION:
policy-map QOS-WAN-EDGE
class QOS-VOICE
priority percent 20
class QOS-VIDEO
bandwidth remaining percent 50
class QOS-CONTROL
class QOS-BUSAPPS
bandwidth remaining percent 15
random-detect dscp-based
service-policy QOS-MARK-BUSAPPS
class QOS-BULK-SCAVENGER
service-policy QOS-MARK-BULK-SCAVENGER
class class-default
bandwidth remaining percent 25
set ip dscp default
fair-queue
^\S
RUNTIME DEVICE CONFIGURATION:
sh run|sec class-map match-any QOS-VOICE
