Automation Scripts
Using python to periodically delete Recycle bin in Infoblox
117     0
I'm trying to use the infoblox_client library in python to access the recycle bin in infoblox and delete 1 week old's object ( not empty the entire bin ) periodically every week.
I'm not able to find the syntax in the library to extract deleted objects from infoblox. Can anyone help ?
