Create Automated Forward-Reverse Report
220     0
How do I create a report on Forward & Reverse mismatches?  Perhaps this has been addressed before with the reporting server?  I thought I had seen this somewhere before.  However, I'm old and that may have been back in the perl api days.  Perhaps I should be doing this via WAPI?
Here is more specifically what I want to know:
- Forward records in my authorative zones that have an IP assignment, but no matching reverse record
- Reverse records that do not have a matching forward record
-- Perhaps make a note of Reverse recods that match, but have more than one forward record
- Forward record with a single address, and the reverse records does not match the forward record
-- Again, perhaps note forward records that have more than one address
-g2
