Dashboard for BloxOne Thread Defense
1527     0
we are using bloxone Thread Defense cloud and I want to see the queries, resonses an the discovered threade in our nios reporting. Therefore I installed a data connector and configured it to send the data to the NIOS reporting. Everything is working fine. I can see the events from the cloud with the sourcetype "ib:dns:capture". What I cannot find is a predefined report or dashboard. Moreover I haven´t found a dashboard for this in the community.
Is a report or dashboard for this or do I have to build it on my own?
kind regards
VJ
VJ
Re: Dashboard for BloxOne Thread Defense
1528     0
Hi Vjockheck,
There are a few preconfigured DNS dashboards. However, I don't believe any solely focused on the data coming form the B1TDC,  so you would likely need to make your own.
Here are a couple links that might help:
https://docs.infoblox.com/display/NAG8/About+Dashboards , see under the DNS Dashboards header
https://www.infoblox.com/wp-content/uploads/infoblox-datasheet-infoblox-reporting-and-analytics-samp...
Thank you,
David
