Infoblox TR-1405 Dashboard Issue
1700     0
<form>
  <label>Customer DNS Report</label>
      <label>Time</label>
      <default>
        <earliest>-1w</earliest>
        <latest>now</latest>
      </default>
    </input>
      <label>Members</label>
      <search>
        <query>index=ib_dns_summary report=si_dns_cache_hit_ratio
               |  stats count by orig_host</query>
      </search>
      <default>*</default>
      <prefix>(</prefix>
      <suffix>)</suffix>
      <valueSuffix>"</valueSuffix>
      <delimiter> OR </delimiter>
    </input>
    <input type="dropdown" token="topn" searchWhenChanged="false">
      <label>Top N</label>
      <choice value="5">5</choice>
      <default>10</default>
      <prefix>top</prefix>
    </input>
    <input type="dropdown" token="dns_view">
      <label>DNS View</label>
      <search>
               | stats count by display_name</query>
      </search>
      <fieldForLabel>display_name</fieldForLabel>
      <fieldForValue>display_name</fieldForValue>
      <default>All</default>
      <change>
        <condition value="All">
          <set token="dns_view_str">*</set>
        </condition>
        <condition value="*">
          <set token="dns_view_str">display_name="$value$"</set>
        </condition>
      </change>
    </input>
    <input type="dropdown" token="ea_site">
      <label>Member Site</label>
      <search>
        <query>| inputlookup __grouping_by_ea_tag_lookup
               | spath input=EA path=Site output=EA_Site
               | stats count by EA_Site</query>
      </search>
      <fieldForLabel>EA_Site</fieldForLabel>
      <fieldForValue>EA_Site</fieldForValue>
      <change>
          <set token="ea_site_str">| noop</set>
        </condition>
          <set token="ea_site_str">| spath input=EA path=Site output=EA_Site
                                    | where EA_Site="$value$"</set>
        </condition>
      </change>
    </input>
    <input type="dropdown" token="group_by">
      <label>Group By EA Tag/Field</label>
      <choice value="none">None</choice>
      <default>none</default>
      <search>
               | eval _raw = EA
               | extract mv_add=t, pairdelim=",", kvdelim=":", auto=f
               | fields - EA, - host, - _raw
               | transpose
               | table column</query>
      </search>
      <fieldForLabel>column</fieldForLabel>
      <fieldForValue>column</fieldForValue>
      <change>
        <condition value="none">
          <set token="group_by_str">| noop</set>
          <set token="time_chart_field">orig_host</set>
          <unset token="show_calculation"></unset>
          <set token="calculation_method">avg</set>
          <set token="group_by_stats">| noop</set>
          <unset token="form.calculation_method"></unset>
        </condition>
          <set token="group_by_str">| spath input=EA path=$value$ output=EA_Val
                                    | eval EA_Val = if(isnull(EA_Val),"(No_Value)",EA_Val)</set>
          <set token="time_chart_field">EA_Val</set>
          <set token="show_calculation">true</set>
          <set token="group_by_stats">| stats avg(PERCENT) as PERCENT by _time, orig_host, EA_Val</set>
        </condition>
      </change>
    </input>
    <input type="radio" token="calculation_method" depends="$show_calculation$">
      <label>Calculation method</label>
      <choice value="sum">Aggregate</choice>
      <choice value="avg">Average</choice>
      <choice value="max">Maximum</choice>
      <default>avg</default>
    </input>
      <label>View</label>
      <choice value="chart">Line Chart</choice>
      <choice value="table">Table</choice>
      <default>chart</default>
      <change>
        <condition value="table">
          <set token="show_table">true</set>
          <unset token="show_chart"></unset>
        </condition>
        <condition value="chart">
          <set token="show_chart">true</set>
          <unset token="show_table"></unset>
        </condition>
        <condition value="both">
        </condition>
      </change>
    </input>
    <input type="dropdown" token="field1"></input>
  </fieldset>
  <search id="base_search">
               $members$
               $dns_view_str$
               $ea_site_str$
               $group_by_str$
               $group_by_stats$
               | timechart bins=1000 $calculation_method$(PERCENT) by $time_chart_field$ where max in $topn$ useother=f
               | interpolate 1200</query>
  </search>
  <row>
    <panel>
      <chart depends="$show_chart$">
        <title>DNS Hit Ratio Trend</title>
        <search base="base_search">
          <query>| noop</query>
        </search>
        <option name="charting.axisTitleX.text">Time</option>
        <option name="charting.axisTitleY.text">Percent</option>
        <option name="charting.axisY">numeric</option>
        <option name="charting.axisY.minimumNumber">0</option>
        <option name="charting.axisY.maximumNumber">100</option>
        <option name="charting.legend.placement">bottom</option>
      </chart>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>CPU Utilization Trend</title>
        <search ref="CPU Utilization Trend"></search>
        <option name="charting.drilldown">all</option>
      </chart>
    </panel>
  </row>
    <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <table depends="$show_table$">
          <query>| sort -_time
                 | rename _time as Time
                 | eval Time=strftime(Time, "%Y-%m-%d %H:%M:%S %Z")</query>
        </search>
      </table>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>DNS Top Clients</title>
        <search ref="DNS Top Clients"></search>
        <option name="charting.chart">pie</option>
        <option name="colorBy">value</option>
        <option name="colorMode">none</option>
        <option name="numberPrecision">0</option>
        <option name="showSparkline">1</option>
        <option name="showTrendIndicator">1</option>
        <option name="trendColorInterpretation">standard</option>
        <option name="trendDisplayMode">absolute</option>
        <option name="useColors">0</option>
        <option name="useThousandSeparators">1</option>
        <option name="mapping.choroplethLayer.colorBins">5</option>
        <option name="mapping.choroplethLayer.colorMode">auto</option>
        <option name="mapping.choroplethLayer.maximumColor">0xDB5800</option>
        <option name="mapping.choroplethLayer.minimumColor">0x2F25BA</option>
        <option name="mapping.choroplethLayer.neutralPoint">0</option>
        <option name="mapping.choroplethLayer.shapeOpacity">0.75</option>
        <option name="mapping.choroplethLayer.showBorder">1</option>
        <option name="mapping.data.maxClusters">100</option>
        <option name="mapping.map.center">(0,0)</option>
        <option name="mapping.map.panning">true</option>
        <option name="mapping.map.scrollZoom">false</option>
        <option name="mapping.map.zoom">2</option>
        <option name="mapping.markerLayer.markerMaxSize">50</option>
        <option name="mapping.markerLayer.markerMinSize">10</option>
        <option name="mapping.markerLayer.markerOpacity">0.8</option>
        <option name="mapping.showTiles">1</option>
        <option name="mapping.tileLayer.maxZoom">7</option>
        <option name="mapping.tileLayer.minZoom">0</option>
        <option name="mapping.tileLayer.tileOpacity">1</option>
        <option name="mapping.type">choropleth</option>
      </chart>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>DNS Top Tunneling Activity</title>
        <search ref="DNS Top Tunneling Activity"></search>
      </chart>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>DNS Top Requested Domain Names</title>
        <search ref="DNS Top Requested Domain Names"></search>
      </chart>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>Top Malware and DNS Tunneling events by client</title>
        <search ref="Top Malware and DNS Tunneling events by client"></search>
      </chart>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <table>
        <title>Threat Protection Event Count by Category</title>
        <search ref="Threat Protection Event Count by Category"></search>
      </table>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>Threat Protection Event Count by Severity Trend</title>
        <search ref="Threat Protection Event Count by Severity Trend"></search>
      </chart>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>DNS Replies Trend</title>
        <search ref="DNS Replies Trend"></search>
      </chart>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>DNS Response Latency Trend</title>
        <search ref="DNS Response Latency Trend"></search>
      </chart>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>Traffic Rate by Member</title>
        <search ref="Traffic Rate by Member"></search>
      </chart>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>DNS Daily Query Rate by Member</title>
        <search ref="DNS Daily Query Rate by Member"></search>
      </chart>
    </panel>
  </row>
  <row>
      <panel>
          <html>
          </html>
      </panel>
  </row>
  <row>
    <panel>
      <chart>
        <title>Memory Utilization Trend</title>
        <search ref="Memory Utilization Trend"></search>
      </chart>
    </panel>
  </row>
</form>
Hello Experts,
Hope you are doing great. I have created custom reporting dashboard in my Infoblox "TR1405" Reporting appilance
with many items. The issue that currently i am facing while changing the date range for a selected member and
submitting the search, it is not getting data for the selected date for all the dashboard items.Appreciate if someone
helping me that how i fix this issue. XML code is attached for ref.
