Issues with Dashboard Reporting on only 2x Reports
1661     0
Dear All,
I am facing issue with two dashboard reports. 1. DNS Replies Trend & DNS Query Rate by Memeber.
Both these reports are fine in Reports section but when i want these reports for a specific member i need to go to dashboard reports. Both these reports are not working in Dashboard Reports tab.
I am getting only search is waiting for an input.
Replies appreciated and awaited.
Regards
Re: Issues with Dashboard Reporting on only 2x Reports
1662     0
I would create a ticket with support to troubleshoot this. If the report works fine, then this could be caused by some misconfiugration in the dashboard's source. If you have the option to- deploy a lab with reporting and replace the source of the dashboard with that of the fresh lab's and see if that fixes the problem.
