VMware
infoblox IPAM with VRA and External VRO
8518     0
Please advise the firewall ports required for infoblox and VRA to communicate.
Usually customers have VRA and embedded VRO but in our senario customer have VRA and VRO on seperate appliance .
Do we have to open a port from both i.e. VRA and VRO or only VRA will communicate with infoblox using plugin which is on VRO for IP and DNS details.
Re: infoblox IPAM with VRA and External VRO
8519     0
When using the plugin, the plugin will connect to NIOS using port 443.
Tony
8519     0
How to setup the Infoblox IPAM Endpoint in VMware vRealize Orchestrator ... For an External vRO, use the URL https://.
liteblue.usps.gov
