API Examples
Problem with csv export using wapi
2081     0
Am trying to export dns zone dumps using wapi.
First dns zone dump gets exported properly however subsequent zone dump export is failing with below error.
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>401 Authorization Required</title>
</head><body>
<h1>Authorization Required</h1>
<p>This server could not verify that you
are authorized to access the document
requested. Either you supplied the wrong
credentials (e.g., bad password), or your
browser doesn't understand how to supply
the credentials required.</p>
</body></html>
This is particulary with recent version of NIOS.Older NIOs versions are working perfectly fine.
Any help is appreciated.
Thanks
AJ
Re: Problem with csv export using wapi
2082     0
Hi Anand,
It looks like an auth issue, but you say the first export is working. I'd still suggest to check the credentials once again. Also, if you could share the different wapi calls that you are using maybe that will give a better picture.
Shukran
2082     0
Hello Shukran,
Thankyou for the response.
Yes, You are right it is seems to be an auth issue.
My requirement is basically to export DNS Zone records of multiple auth zones from a particular Grid Manager.
Am running a for loop passing zone names to csv export wapi calls to the same Grid Manager thus credentials remain the same irrespective of zone passed.
Procedure -
1.Generating token for a particular zone using below wapi call
curl -k -u xxxx:xxxx -H 'content-type: application/json' -X POST "https://x.x.x.x/wapi/v2.9/fileop?_function=csv_export" -d '{"_object": "allrecords","view": "default","zone": "zone_name"}'
2.Downloading CSV file
curl -k -u xxxx:xxxx -H 'content-type: application/force-download' "https://x.x.x.x/http_direct_file_io/req_id-DOWNLOAD-0220145046916620/Zonechilds.csv" -o "Zonechilds.csv"
3.Removing Stored Token
curl -k -u xxxx:xxxx -H 'content-type: application/json' -X POST "https://x.x.x.x/wapi/v2.9/fileop?_function=downloadcomplete" -d '{"token" :"token generated in step 1\n"}'
CSV Export is working fine for 1st zone, however, failing with 401 status for subsequent zones. Also issue is with recent NIOS releases.
AJ
2082     0
I can assure you it works, I have a script I use on a regular basis that does exactly this.
Maybe check if there's an authentication policy defined, for simultaneous logins, or if there's a web proxy getting in the way, or something like that.
What language are you working in?  There should be a method to store and re-use the authentication cookie.  That would minimze the number of authentications you're performing, which will help slightly with performance and maybe with this issue too.
2082     0
Am using shell scripting.
Could not find anything in the authentication policy as such but I do suspect there is something related to configuration.Will explore further.
There is no web proxy in between.
In my understanding, there is a separate token & url for file download for each zone hence not sure if authentication cookie came be re-used.
Thanks
AJ
2082     0
Try this.  It's printing lots of extra info, all those extra echo commands can be removed.
#!/bin/sh
GM="gm.example.net"
GM_USER="admin"
GM_PASS="infoblox"
GM_WAPI="v2.11"
ZONES=("example.net", "10.in-addr.arpa")
for ZONE ("$ZONES[@]")
do
	echo "Exporting $ZONE"
	CMD="curl -k -u $GM_USER:$GM_PASS -H \"content-type: application/json\" -X POST \"https://$GM/wapi/$GM_WAPI/fileop?_function=csv_export\" -d '{\"_object\":\"allrecords\",\"view\":\"Internal DNS\",\"zone\":\"$ZONE\"}'"
	echo $CMD
	RESULT=$(eval $CMD)
	echo $RESULT
	URL=$(jq '.url' <<< $RESULT)
	TOKEN=$(jq '.token' <<< $RESULT)
	echo "==============="
	echo "URL:"
	echo $URL
	echo "TOKEN:"
	echo $TOKEN
	CMD="curl -k -u $GM_USER:$GM_PASS -H \"content-type: application/force-download\" $URL -o \"$ZONE.csv\""
	echo $CMD
	# Downloading CSV file
	RESULT=$(eval $CMD)
	echo $RESULT
	# use token to clear downloaded file
	CMD="curl -k -u $GM_USER:$GM_PASS -H \"content-type: application/json\" -X POST \"https://$GM/wapi/$GM_WAPI/fileop?_function=downloadcomplete\" -d '{\"token\" :$TOKEN}'"
	RESULT=$(eval $CMD)
	echo $RESULT
done
2082     0
Dear All,
Working with cookie re-use.
Problem stands resolved.
Thanks to all for their valuable inputs.
AJ
