How to create Network insight automatic conversion rules ?
5588     0
After use Network insight auto discover , got huge unmanaged network and ip address .So i want add a automatic conversion rules for auto convert all unmanaged ip to fixed address .
I Try following admin guide set a policy , but failed many times .
So anybody can help give a automatic conversion rule example for auto convert all discovered unmanaged ip to fixed address ?
Re: How to create Network insight automatic conversion rules ?
5589     0
Ever find a solution?
5589     0
The documentation in the context sensitive help has a number of errors which are adressed in NIOS 8.4.0
We also updated the admin guide on the matter and you should be able to copy-paste examples from the following page and substitute the domains for your own:  https://docs.infoblox.com/display/nios84/About+Automatic+Conversion+Rules
