Issue with incorrect DNS records for Anyconnect VPN clients
1910     1
We are having an issue where clients are not updating DNS records when using VPN.  We have an Cisco Anyconnect  VPN solution and the firewall acts as the DHCP server.  The A records and PTR records are not being updated, which is creating issues for our SCCM team trying to connect to clients on the network.  I'm engaging our firewall team to see if DDNS can be enabled to have the FW send updates on behalf of the client, but so far they are not sure it will solve the issue.  Another option the firewall team and I are discussing is moving the DHCP to the Infoblox server, but there are other potential external issues that may prevent that from working.  Anyone have any other suggestions?   Our grid master is a 1410 DDI and we are running version 8.4.8
Thanks for any assistance anyone can provide.
Re: Issue with incorrect DNS records for Anyconnect VPN clients
1911     1
Have the same issue. Would have been keen to see the resolution on this question.
1911     1
If configuring static records (Host) in DNS server is not an option, we suggest enabling DDNS in the DHCP server. DHCP server can update the DNS records on behalf of clients. You can start by referring Admin Guide section "Configuring DHCP for DDNS". If you have a lab environemnt, testing the same would help to know if there are any potential issues arising for your clients.
1911     1
go to Zone  delegated for workstation DDNS
suppose wks.org.com
go to zone properties of this domain ,refer "updates"  and verify "Allow Updats from"
there 3 option Non, Named ACL, Set of ACE's
depending upon option selection proceed with next action
ACL is just restriction in place to allow DDNS
This widget could not be displayed.
" class="expert-of-month-image"/>
