[Need Advice] IPAM for Large Scale ISP
2208     0
Hi Experts,
I would like to know your thought about what option can i choose between NetMRI or Network Insight for IPAM in Large Scale of ISP its around 10M IPs.
Thanks
Re: [Need Advice] IPAM for Large Scale ISP
2209     0
To my knowledge, teh difference between NetMRI and Network Insight is support for automation.  Network Insight supports network discovery, adding that data to IPAM.  NetMRI has the same engine and can update IPAM on a schedule, but it also adds network automation features which can push network changes, identify network issues, and store configuration changes a configured time period.  If you only want discovery, go with Network Insight.  You will need to work with your account team to size the infrastructure.  You'll need more than one probe appliance for sure, sending to one or more consolidator appliances which will update IPAM.
This widget could not be displayed.
" class="expert-of-month-image"/>
