Need Help: How to Create multiple values for extensible attributes for Ipv4 address
1482     0
Hi Team,
I want to know is it possible to create a multiple extensible attribute for any filed such as Ticket Number Or Site Or Buliding using WAPI?? If yes, please let me know the way.
I didnt find any in the Infoblox API documentation.
Re: Need Help: How to Create multiple values for extensible attributes for Ipv4 address
1483     0
Yes it is possible.  First the extensible attribute must be configured to allow multiple values.  Then the values can be sent as an array of values:
        "extattrs": {
            "Solution": {
                "value": [
                    "Mobile",
                    "Client"
1483     0
This solution helped me a lot..
Thank you so much!!!
