THE GAME HAS CHANGED
Need help with adding a custom field to API call
2801     0
I am new to the community. I work on ServiceNow and trying to build integration between Infoblox and ServiceNow. My goal is to pull DHCP subnet data and document it in ServiceNow. Part of the process I am using the following API call where I am pulling Network, Comment columns and also a custom column that was added by our Infoblox team. Below is my sample call where I am trying to add a custom field(my_custom_field) but running into issues because API doesn't recognize the custom columns. Not sure what I am missing, appreciate any insight into adding the custom field to the '_return_fields'.
-->https://mycompanyurl/wapi/v2.3./network?_return_fields=network,comment,my_custom_field
Re: Need help with adding a custom field to API call
2802     0
Custom fields are always Extensible Attributes (EAs).    Ask for the "extattrs" field to be returned, and then all EA attribute/value pairs will also be returned.
