THE GAME HAS CHANGED
Automation Scripts
ANSIBLE network_container already exist
2837     0
Hello.
I try to configure new containers in my IB grid from an ansible playbook with the following task
  ##### CREATE ALL CONTAINERS #####
  - name: ===> Create/Delete ALL CONTAINERS
    infoblox.nios_modules.nios_network:
      provider: "{{ nios_provider }}"
      state: "present"
      network: "10.22.0.0/16"
      comment: "network 10.22"
      container: true
    connection: local
    ignore_errors: yes
All th contaziners are created the first tie I run the aansible-playbook, that is good.
But when I run again the playbook (withjout any modification) I have  the following error from each item.
fatal: [myGRID]: FAILED! => {"changed": false, "code": "Client.Ibap.Data.Conflict", "msg": "Duplicate object '10.22.0.0' of type 'network_container' already exists in the database.", "operation": "create_object", "type": "AdmConDataError"}
And I have the same behavior with 'network' object (OK the first time and fails time after)
I can not find where is the error.
Any idea ?
Note : I have temp_licences on a vNIOS (VMware VM)
Thx
Re: ANSIBLE network_container already exist
2838     0
When you run the playbook for the first time it runs as expected and creates the network/network container with the network configurations that you have mentioned.
When you run the same playbook again (without any modifications), it runs the same task again where it tries to create same objects again in NIOS and as you see in the error message it mentions that it is a duplicate object and it already exists.
So you can either update the configuration in the playbook before running it again or if you want to run the same playbook (to create the same objects again) you need to delete the existing ones first.
Below is a snippet for deleting the network object
tasks:
   - name: delete network
       network: 10.0.0.0/24
       network_view: default
       state: absent
   - name: delete network container
       network: 10.0.0.0/8
       state: absent
You can refer the given link for a better understanding of Infoblox NIOS module for Ansible
Shukran
Shukran
2838     0
Thanks Shukran
If I delete network/network container, it will remove all the included configuration (host objects DHCP ranges and so on). It is something that I have to avoid.
Is there a way to update an object whith no suppression step ?
Thanks again.
Vincent
2838     0
Hi Vincent,
Okay, could you let me know why are you trying to run the same playbook again? Is is to update the object?
The playbook that you have creates the object. You may have to modify it if you want to update it, right now you are trying to create a duplicate object that's why it fails.
Shukran
Shukran
2838     0
Hi Shukran
Yes the point is that I want to update the object if it has been created previsouly. My goal is to be sure that the objects are configured as defined in my source of Truth. A scheduled job should be used to do that.
And I really do not want to delete before recreate.
Thanks again.
Vincent
