THE GAME HAS CHANGED
Automation Scripts
Generate custom issue in python
3584     0
Hello, I followed the example from the "Getting started with 5 scripts' to generate a custom issue in python. After some minor modification, my script runs without error but the custom issue created doesn't contain the attributes (defined as string) Device, IPAddress, and Contact in the Custom Issue.Am I missing something?
import requests, json, re
from infoblox_netmri.easy import NetMRIEasy
# This values will be provided by NetMRI before execution
defaults = {
"api_url": api_url,
"http_username": http_username,
"http_password": http_password,
"job_id": job_id,
"device_id": device_id,
"batch_id": batch_id
# Create NetMRI context manager. It will close session after execution
    device = easy.get_device()
    easy.log_message('info', device_devicename)
    snmpcommand = easy.send_command('show run | incl contact')
    devicecontact = snmpcommand.strip("snmp-server contact ")
    issue_id = easy.generate_issue("NewDiscovery","Info",**{
        "Device": device_devicename,
        "IPAddress": device_deviceipdotted,
        "Contact": devicecontact,
Re: Generate custom issue in python
3585     0
Can you post a Screen Shot of your Custom Issue as well?
https://sifbaksh.com
3585     0
Sorry for the late reply. I was able to solve the problem. My confusion was due to the different "default" variables in python and NetMRIEasy.
