Get Exclusion Range from WAPI
9932     0
I need to extract by using the WAPI all the exclusion range inside of a DHCP Range.
By looking at the WAPI Doc it says that the EXLUDE field of the DHCP Range is not available for search.
Does anybody know how should I do the GET to be able to receive all the exlusion range given an specific DHCP range?
Thanks in advance,
Alan Roitman
Re: Get Exclusion Range from WAPI
9933     0
Hi Alan,
Here is a sample wapi call for getting all the reserved ranges in your grid. You can tweak this to suite your requirements.
curl -k -u admin:xxxxxxx -H "Content-type: application/json" -X GET https://xx.xx.xx.xx/wapi/v2.7/range -d '{"member" : null}'
The member field is searchable, so the idea here is to search for all the ranges where the member field is null.
Sandeep
