THE GAME HAS CHANGED
Automation Scripts
help Find & replace & apply
5280     0
Hi
I have a Core Sw has a set of DHCP, number of them does not have the correct name but in settings I can distinguish voice vlan via option 150.
ip dhcp pool_FG (VLAN 76)
   network 10.16.76.0 255.255.255.0
   default-router 10.16.76.254
   option 150 ip 10.128.1.11 10.172.50.11
   lease 90
I want to look for this dhcp and take the address.
10.16.76.0
And apply This commend to the router:
ip access-list extended allow-voice-tr
permit ip 10.16.76.0 any
Thanks for any info.
Re: help Find & replace & apply
5281     0
Hey,
Check out the getting started with CCS content on our github repository: https://github.com/infobloxopen/netmri-toolkit/tree/master/CCS/StartHere
On a basic level you want an action command to ouput that ip dhcp statement and filter for the ones with option 150 (IOS has "include" for that) Then use a trigger to  filter out networks and then another action command to apply the acl.
If you want to go a bit deeper then you could first check to see if the acl already exists and skip this device if it does. Or you could run this only on devices that don't have this acl by starting from the config search
5281     0
Dear ingmar,
Yes this is exactly what I look for, and after the fetch for all IP addresses for voice Subnet, The script will up date access-list . If the script can to check first befor apply the access-list it be fantastic.
Great content on your github repository. but nothing can help me in this task.
5281     0
This is an untested draft, I don't have any dhcp on IOS so can't test this. You will probably have to modify this for it to work.
## Export of Script: ACL update for voice basedon option 150 in DHCP
## Script-Level: 3
## Script-Category: Uncategorized
Script:
Script-Description:
	'ACL update for voice basedon option 150 in DHCP"
Script-Filter:
	$vendor in ["Cisco"]
Action:
	Show IP DHCP config
Action-Commands:
	show ip dhcp | include i network p 1 n 3
Output-Trigger:
	Parse Output
Trigger:
	Parse Output
Trigger-Variables:
	$network ip
Trigger-Template:
	network\s[[$network]]\s
Trigger-Commands:
	conf t
	permit ip $network any
	exit
Action-Commands:
	exit
	write mem
5281     0
No luck yet,
I couldn't reach my goal
Thanks for your help
