THE GAME HAS CHANGED
Automation Scripts
Trouble with substring in python
3976     0
Has anyone tried to manipulate strings in python with NetMRI?
Basically, I'm trying to pull the first 4 characters of the device's name and stored it in a new variable. NetMRI gives me an error but the same python code works in a another Linux environment. Any workaround for this?
This code works fine in another Linux platform:
>>> device = 'baltrouter1'
>>> print(device[:4].upper())
BALT
This python code (2nd print command) doesn't run in NetMRI:
mydevice = 'baltrouter1'
print(mydevice)
print(mydevice[:4].upper())
NetMRI Status Logs:
+++ Looking up device information ...................................... OK
+++ Looking up job specification information ........................... OK
+++ Loading ccs file ................................................... OK
+++ Script: script_xyz
+++ Script-Filter ...................................................... MATCH
baltrouter1
*** ERROR: Error 'Traceback (most recent call last):
File "<stdin>", line 170, in <module>
TypeError: 'str' object is not callable
Python script has returned 1 value
Re: Trouble with substring in python
3977     0
I just ran the following and got these results:
Code:
# Create NetMRI context manager. It will close session after execution
    print(mydevice)
Results:
+++ Script: f
baltrouter1
BALT
I'm running 7.4.2
https://sifbaksh.com
3977     0
Python has no substring methods like python substring() or substr(). Instead, you can use slice syntax to get parts of existing strings. Python slicing is a computationally fast way to methodically access parts of your data. The colons (Smiley Happy in subscript notation make slice notation - which has the arguments, start, stop and step . It follows this template:
Parameters are enclosed in the square brackets.
Parameters are separated by colon.
string[start: end: step]
  • start - Starting index of string, Default is 0.
  • end - End index of string which is not inclusive .
  • step - An integer number specifying the step of the slicing. Default is 1.
