Topic Options
NetMRI script not working
Options
09-20-2020 02:02 AM
2556     0
Hi all,
Am having trouble to change the password for juniper devices by using below script , it is not working kindly help me
# BEGIN-SCRIPT-BLOCK
# Script-Filter:
# $Vendor in ["Juniper", ]
# Script-Variables:
# $username word "su"
# $password password "simple123"
# END-SCRIPT-BLOCK
use strict;
use warnings;
use NetMRI_Easy 0.6;
our $username;
our $password;
my $easy = new NetMRI_Easy({ api_version => 2.5 });
if($easy->vendor eq "Juniper") {
$easy->send_command("configure");
$easy->send_command("set system login user $username authentication plain-text-password”, “password:”);
$easy->send_command($password);
$easy->send_command("show | compare");
$easy->send_command("commit");
$easy->send_command("exit");
# Script-Filter:
# Script-Variables:
# END-SCRIPT-BLOCK
use strict;
use warnings;
our $username;
our $password;
Re: NetMRI script not working
Options
09-21-2020 01:47 PM
2557     0
Try this one
########################################################################### ## Export of Script: JuniperPassword ## Script-Level: 3 ## Script-Category: Config ########################################################################### Script: JuniperPassword Script-Description: This script updates the nccm account password on Juniper devices. Script-Filter: $Vendor eq "Juniper" # Will not work currently - Trigger-Context-Password currently only accepts a # static value (i.e. passing a variable to Trigger-Context-Password will not work) #script-variables: (in lower case to avoid GUI accidently picking this up # $password password "" ################################################## Action: Set Juniper Root Password Action-Description: This script updates the root password on Juniper devices. Needs password hard coded in script. Action-Commands: configure Output-Triggers: SetPassword ################################################## Trigger: SetPassword Trigger-Filter: true Trigger-Context: true Trigger-Context-Enter: set system login user nccm authentication plain-text-password Trigger-Context-Password: # Change InsertYourPasswordHere on the following line to the desired password # for the nccm account. InsertYourPasswordHere Trigger-Commands: commit
https://sifbaksh.com
