Are there best practice defaults for system thresholds?
330     0
Hi;
Are there best practice defaults for system thresholds? For example:
. CPU temperature warning threshold
. CPU temperature critical threshold
. CPU load warning threshold
. CPU load critical thresholod
. Memory usage thresholds
. Swap usage thresholds
Kindly
Wasfi
Re: Are there best practice defaults for system thresholds?
331     0
These values originate from the manual - NIOS_8.6_Documentation.pdf
It is less about warning/critical, more about trap trigger/reset.   For a warning/critical, you would SNMP poll and warning would be above the reset, critical above the trigger ...
CPU temperature warning threshold/CPU temperature critical threshold - There does not appear to be a Trap for this.   ibCPUTemperature is available from SNMP, and there is of course the LOM if enabled (example in doc).   I would look at the Intel ARK document for finer details depending on the model of CPU you have.
CPU load warning threshold/CPU load critical threshold - trigger 81%, reset 70%
Memory usage thresholds - trigger 90%, reset 80%
Swap usage thresholds - trigger 50%, reset 30%
