DDNS Client problem
400     0
Hello. I am trying to properly configure DDNS in my environment.
I am using DHCP and DNS on the NIOS.
However, when the test client runs ipconfig /registerdns, I get this:
"... update 'lab.local/IN' rejected"
I can't figure out which setting is preventing the update
Re: DDNS Client problem
401     0
Can you share a little more information on your config?
Is your Infoblox system the owner/authoritative for the .local domain?
Is it configured to allow dynamic updates? from where?
is DHCP configured to send updates to that zone?
