Rogue device detection
498     0
We use InfoBlox in our organisation, primarily for DHCP functionality. I am reaching out to see if there is an option within InfoBlox to detect an unauthorized machine requesting a DHCP address?
Is there any way you can run a report that can inspect the hostname and flag anything non conforming i.e first 4 characters of hostname for example?
Kind Regards
Amit
Re: Rogue device detection
499     0
If you have Infoblox reporting solution in place, you may explore the data within ib_dhcp_lease_history index(Something like : NOT OPTION12HOST="startstring*" etc). Note that there are other indexes that you could explore too.
Best regards,
Mohammed Alman
