Help for upgrade path
2899     0
Hi all,
please give me a good step upgrade vNIOS from version 8.3.0 to 8.5.2.  I need upgrade to refreshment existing Grid from IB-V1420 to 1425.
Re: Help for upgrade path
2900     0
You can direcly upgrade 8.3.8 and earlier release (includ 8.3.0) to 8.5.2
This information can be found on 8.5.2 release notes too
2900     0
Hi, Upgrade for standalone is as below Step1) UPLOAD 1. In the Grid tab, select the Upgrade tab, and then click Upload in the panel or from the Toolbar 2.Navigate to the directory where you have stored the NIOS software upgrade, and then click Open or Upload Step 2) DISTRIBUTE 1.From the Grid tab, select the Upgrade tab, and then click Distribute -> Distribute Now from the Toolbar. 2.In the confirmation dialog box, click Yes to start the distribution Step 3)C. TEST UPGRADE 1.From the Grid tab, select the Upgrade tab, and then click Test Upgrade from the Toolbar. Step 4)UPGRADE 1.From the Grid tab, select the Upgrade tab, and then click Upgrade -> UpgradeNow from the Toolbar. HOWEVER We like to know about upgrading Forwarders HA Pair and Authoritative Grid Master ---------------------------------------------------------------------------------------------------------------------- 1) When we upgrade DNS forwarders Active and Passive , after upgrade which box will be the active one ? any down time ? 2) When we upgrade DNS Authoritative server with secondary gridmaster , How can we schedule with no impact to services. Thanks
NTP time is 35 mins after Upgrade - unable to change time
2900     0
Infoblox upgraded to 8.5.5 the n to 8.6.2
after upgarde NTP is out of syn and time shows 35 mins less that correct time
on infoblox it is set tp external source and time is greyed out and unable to change
please advise how to fix this as lot of servers pointing to this NTP server.
Thanks
Re: NTP time is 35 mins after Upgrade - unable to change time
2900     0
If you are in 8.6 you can likely use:
set maintenancemode
synctime
But you should probably turn in a support ticket
Thanks
Get Outlook for Android<>
