Azure
Azure wizard forces configuration of MGMT interface
895     0
Hey, anyone have any advice for the mgmt port in Azure? We don't need it, all comms is going to go through LAN1, but the Azure marketplace wizard is forcing us to configure it - I guess it's just making sure it's connected so that if you need to use it then it's available, but I don't need it and don't have a subnet to connect it to - I guess I could create a "dummy" subnet to connect it to? Has anyone else done this?
Paul Roberts
PCN (UK) Ltd
Re: Azure wizard forces configuration of MGMT interface
896     0
Hi Paul,
NIOS on Azure does currently require the 2 network interfaces to successfully deploy and boot. If you are not intending the use the MGMT interface, creating a small "dummy" subnet to drop that interface on is a workable option.
Jason
