Need clarification for inheritance of EAs
1056     0
Hi All,
I have an infoblox IPAM setup with Network containers and Networks with different mix of Inherit/Override of the attributes. I am trying to import csv to update attributes(Inheritance Enabled) on Network Containers, Is it correct that updating an attribute value on a container will update the value on all the descendants as well regardless of the descendents having diffenrent value with Override configured.
Is there anyway to modify csv in which we can stop it from chaging value on descendants?
Re: Need clarification for inheritance of EAs
1057     0
There are parameters you can use to affect the inheritance handling:
https://docs.infoblox.com/space/nios90/280661843/Importing+Inheritable+Extensible+Attributes
Unfortunately with CSV you cannot change that behavior for child objects.  You can, for GUI and API actions however.
