Power Supply 1 removed alert from Infoblox NIOS (Model IB-V1415).
283     0
Received Email alert that Power Supply 1 is removed.
what could be the cause.
From the logs, I could see the PSU 1 alerts was sent around 17:52 today,
2024-12-26T17:52:19+08:00 user ns2.nets.com.sg monitor[166530]: err Type: Power Supply, State: Yellow, Event: Power supply 1 removed. -
The appliance still detects the PSU1 but there are no power input,
ns2(A) > show hardware_status
CPU_TEMP: 27 C
SYS_TEMP: 24 C
POWER: Power #1 [no data]
POWER: Power #2 OK TYPE:AC FRU-IDSmiley TongueWS-606P-1R SNSmiley Tongue606PCK2^UT1190
FAN1: 9400
FAN1: 9300
FAN1: 9000
FAN1: 9600
FAN1: 9700
FAN1: 9200
 Item                           |                          Value
 Status                         |                OK[UNIT IS OFF]
 Input Voltage                  |                        232.5 V
 Input Current                  |                         0.08 A
 Main Output Voltage            |                         0.00 V
 Main Output Current            |                         0.00 A
 Temperature 1                  |                        33C/91F
 Temperature 2                  |                        30C/86F
 Fan 1                          |                          0 RPM
 Fan 2                          |                          0 RPM
 Main Output Power              |                            0 W
 Input Power                    |                            3 W
 PMBus Revision                 |                           0x22
 PWS Serial Number              |                P606PCK26UT2220
 PWS Module Number              |                    PWS-606P-1R
 PWS Revision                   |                            1.2
 Current Sharing Control        |                  Not supported
Please advise
Thanks
Re: Power Supply 1 removed alert from Infoblox NIOS (Model IB-V1415).
284     0
Please note that There were no activity at the DC and the Power source is good.
284     0
Power supply is found faulty.
means
Power Supply 1 removed alert --> power supply s faulty . need to replace PSU
