Possible to grow volume on TR-5005 virtual reporting appliance?
- Email to a Friend
10-09-2019 08:26 AM
I'd like to know if it's possible to grow the second volume (where reporting data is stored) on the virtual appliance TR-5005. Since this is a virtual appliance I should be able to grow the volume in VMware and since NIOS is based on Linux I thought there might be access to a privleged command to grow the volume.
Solved! Go to Solution.
Re: Possible to grow volume on TR-5005 virtual reporting appliance?
- Email to a Friend
07-29-2020 01:14 AM
It seems that we cannot enlarge the disk size of TR5005.
Alternatively, you can backup the reporting data and then disconnect the TR5005. Provision another TR5005 with a larger disk volumn to join into the Grid using the same IP information. After the service is running, you can restore the reporting data into the new TR5005.
- Email to a Friend
07-29-2020 09:40 PM
Just adding to the previous update that there is a feature enhancement request (RFE-8119) which is still open with Infoblox Engineering to support resizing of reporting storage in VMs
- Email to a Friend
07-30-2020 10:31 AM
To my knowledge(if I recall correctly), TR-5005 appliances are the only model that allow resizing the reporting partition after enabling the reporting service on it. I say, its worth a shot to try expanding the 2nd storage after shutting down the VM (also take a reporting data backup- just in case).
- Email to a Friend
09-05-2020 12:12 PM
That's right, we can only resize the TR-5005
- Email to a Friend
01-11-2021 03:09 AM
you say it is possible. How???
we can enlarge the VM yes, but on the reporting member it stays the same.
- Email to a Friend
02-18-2021 08:07 PM
i have tested that the 5005 storage can be enlarged, but Infoblox cannot detect the change of volume.
alternative, i sugget to backup all report data in Grid and then disconnect the existing 5005. Deploy a new v5005 with larger storage to re-join the Grid. finally, restore the report data to the Grid
